TeraFlex PreRunner Shock Tech Video
Actually that was the 3rd 2dr JK of TeraFlex's that crashed, No1 and No2 2dr got sold.
could the 3 or 4 inch teraflex LA kit be coverted into a prerunner easily? what shocks are those specifacally and is it possible to use them with the regular LA lifts? how much lift does the teraflex give?
Our R&D driver Curt spent a lot of time with FOX on getting the valving just right for this type of driving. FOX shocks really shine when it comes to this type if driving. Now you can still run ELKA's in the PreRunner if you want to. I don't have a PreRunner kit, but that doesn't stop me from driving like it.
FYI I have a 4" LCG/SpeedBumps/ELKA's installed.
Both the 3"/4"/6" LA and PreRunner kits use all the same brackets/arms EXCEPT the PreRunner uses straight rear lower arms. The PreRunner uses different rear SpeedBumps than the normal SpeedBump kits. They require the frame to be notched and sleeves welded in place. I'm looking at doing this myself.
Standard rear TeraFlex SpeedBumps 3"-4" #1954760
TeraFlex PreRunner rear SpeedBumps #1958260
FYI I have a 4" LCG/SpeedBumps/ELKA's installed.Standard rear TeraFlex SpeedBumps 3"-4" #1954760
