after putting a lift in
Old Jun 9, 2011 | 06:04 AM
girom80's Avatar
Default after putting a lift in
i jus in the teraflex 2.5 bb with shocks and got a alignment the other day is there anything else i should do after the lift?
Old Jun 9, 2011 | 06:05 AM
TROUPP's Avatar
supposed to recheck bolt tightness at some point, most people never do.
Old Jun 9, 2011 | 06:07 AM
wayoflife's Avatar
JK-Forum Founder
honestly, you didn't really need to get an alignment as there wasn't a whole lot they could do other than recenter your steering wheel. but, as mentioned, check the torque setting on your bolts after about 100 miles of use and then enjoy
akoop's Avatar
Did you install the BB yourself? If so how did the install go? Any suprises? I am thinking about that for my next project.
Old Jun 9, 2011 | 06:09 AM
girom80's Avatar
yea did it myself with 2 friends pretty simple no suprises. and my dealer told me after i do the lift to bring it in so he could reset the pinion point? thought that was after getting tires?
Old Jun 9, 2011 | 06:18 AM
wayoflife's Avatar
JK-Forum Founder
unless your lift came with adjustable rear upper control arms, your dealer won't be able anything other than to charge you for doing squat.
Old Jun 11, 2011 | 08:57 AM
TROUPP's Avatar
As you do the lift, the toe seems to get pulled inward on these, so the steering wheel maybe straight, but the toe-in will most likely be off.
Old Jun 11, 2011 | 09:08 AM
Hook-Em's Avatar
I'm surprised nobody said the most obvious of all responses to the question...
WHEEL IT!
Old Jun 11, 2011 | 09:30 AM
JayhawkJeep's Avatar
Veteran: Navy
Drive it like you stole it.
Old Jun 11, 2011 | 10:15 AM
searlo's Avatar
I just got done this lift yesterday as well! The only thing I am thinking is an adjustable front track bar??? any suggestions, comments on this idea. Will it improve handling on a 2.5 inch lift or would it be a waste of money???? They give you the drop bracket for the rear, so I would assume that something for the front would be good as well, not sure why they didnt include a front bracket??? hmmm
