ebs esp lights on and the stering wheels no longer in the middle
ok all mighty JK forum members this is my issue see if any one can help out with me with it my esp ebs light came on last week and now the stering wheel is no longer in the middle . any thoughts thanks
did you recently wheel it or did you put a lift on? that is what it sounds like to me. go to the write up section and you will find a write up on " do it yourself front end alignment". Steering wheel is an easy fix that only takes about 15 min. to get it right. this should solve the problem.
yeah, if you installed a lift, adjust the draglink for sure. If you just went wheeling and its like that now, you bent something. Check the entire suspension. After centering the wheel, your light should go off.
