Need help driving tomorrow with new gears
So I finally added my 5.13 gears to my jk and I did all the break in stuff change out oil and drove a little towards home which have to go through mountains. Is it normal when I'm driving up a steep hill I'm at around 70mph and all of a sudden it's like I loose all power with foot on pedal still and end up around 55mph before I get to flat ground or down hill then back to normal unless I step in has and shoot up too about 3000 rpm. Is that normal and ok to do? Do I leave OD on? Turned it off once and didn't see much improvement. Any tips please
I posted this earlier and never was able to get a answer. It was always questions or others talking back and forth and that don't help me. Anyways. I have a 08 jk auto 4 dr. I added 5.13 gears and yes I have broke them in by 500 miles and changed out oil. I do have a superchip and programmed my gears and tire size but for some reason when I was driving home the other day thru the mountains and happens here on hills. When I go up hills my speed decreases and will settle around 50-55 even if I have the pedal wear I normally go 70 at. Unless I push down the pedal and get my rpm to 3000 with OD on. I try turning OD off but still no difference really. Is this normal? Or what should I do or recommendations?
