lost power steering after body lift?
So i put on a rough country 1.25 body lift yesterday and it went very well concidering i had to remove 36 bolts and put 36 bolts back on. I would HIGHLY suggest you use power tools where you can. I used a conpressor for about half.
Everything is back to gether, love the added lift.
BUT now my power steering is out? I check fluid and figured i pinched a line or pulled one off but everythings seems to be in order.
Does anyone have some suggestions of what might have happened as i cant seem to see what went wrong.
fyi the rough country lift is awesome! what singles it out is the bumber relocation bracket. havent got to that yet though....
thank you for any input, ppl on here are rad so first place i thought to go.
Mad P
Mad P
I looked over everything again and cant still cant seem to see the issue except......
Below picture show steering shaft and it looks like it may have been pulled out to far and is either stuck or f%&@#. Does this look right?
x2 They splines may be not completely together and are still touching giving you the sense that you have steering but only when you force the wheel. Have someone turn the wheel and have a look at it and see if its smooth or not. Has to be a line from the power steering side, you'll want to have a real good look as to not burn out your PS system.
