smittybilt src rocker "protectors"
Old Jun 11, 2011 | 05:40 PM
rubi08unlimited's Avatar
Default smittybilt src rocker "protectors"
Well, I found that the protectors or sliders may have done more damage than if I had none at all. the upright tubing that connects the upper and lower horizontal bars dented the rocker panels of my jeep in the center and the front. I never did like that there was no middle support where it attached to the jeep but assumed that Smittybilt would have tested these before selling them. pressure between the points where it connects to the jeep pushes the uprights to make contact with the rocker because of the lenght of span with no support Has this happened to anyone else and if so, is there any recourse with Smittybilt?
Old Jun 11, 2011 | 05:48 PM
Deere_Jeep's Avatar
literally just finished putting these on. I have read that this is a possibility and might add the third support. How hard did you slide it on something?
Old Jun 11, 2011 | 05:50 PM
HIROLLR's Avatar
I have these and thought they looked sturdy. I assumed and had several people comment on how they looked heavy duty and should offer a lot of protection? I have a 2 door........I see from the pics in your profile that you have a 4 door. Does the 4 dr rockers have a middle support? I assume from your post that it doesn't. Even as heavy as the tubing is, only 2 mounting pts on the span of a 4 dr would be weak????
What did you hit?
Old Jun 11, 2011 | 05:52 PM
HIROLLR's Avatar
Default Pictures?
Post a picture of the damage.....
Old Jun 11, 2011 | 06:07 PM
Croce's Avatar
My SRC would bend if I hi-lifted them in the middle. I called Smittybilt customer service and they made it right. I highly suggest you do the same. The XRC's are much more durable for wheeling. The src seems to just be protection rather than sliders
Check out this thread
https://www.jk-forum.com/forums/show...-Guards-beware!
Old Jun 12, 2011 | 07:39 PM
Ima try to get a pic tomorrow. I dropped about 6 inches or so onto a rock and it put a little dent towards the front of the passenger side rail but the damage to the rocker was much worse with nothing to support it :(
Old Jun 12, 2011 | 08:12 PM
JP Brechter's Avatar
I just did mine today. I have a 2010 4-door. Installation wasn't fun until I figured out that you have to ream one of the holes to get them to fit properly. After that the passenger side went in smooth. It would have helped if Smittybilt included instructions so I didn't remove the body bolts just to find out that you don't have to. They should have also moved the front most hole 1/4 inch so I wouldn"t have to ream & file the hole. My third complaint is that there is no middle support. Why only use 2 of the 3 supports? They're there. Use them for extra support. Other than that they look Midevil.
So if you plan on doing it yourself here is what you should know...
#1. DO NOT use air tools. You WILL strip the nuts. Do it all by hand with a 16mm socket and small extention.
#2. DO NOT remove the body bolts or the middle side nuts. You're wasting your time.
#3. Ream the front most hole closest to the front tire on both sides about 1/4 inch. Start with a steel drill bit and finish with a round file by hand.
The rest is cake
Old Jun 12, 2011 | 08:21 PM
The rest is cake
Until you hit a rock...
Old Jun 12, 2011 | 09:24 PM
TXCheney's Avatar
Wow, these were on the top of my list for next mod. Now I need a plan B, and probably even more $$$.
Old Jun 12, 2011 | 09:48 PM
adrom's Avatar
look at ace sliders. cheap and are very recomended. im about to get some when i can ok it with the "bank"
