Best Way To Black Out Lights
I couldn't find any cheap replacements for mine so I ended up spraying them. It's very easy to do and look great. Only costs $20 as well.
Here is what i did:
-disconnect lights
-remove bulbs
-remove housing
-scuff the lens with a 3m scuff pad
-spray 3 very light coats of Nite-shades paint (let dry after each coat)
-spray 3 coats of clear (let dry after each coat)
-reinstall
If you didn't have to let the paint dry this is a 10 minute mod. Super simple
Here is what i did:
-disconnect lights
-remove bulbs
-remove housing
-reinstall
Would hope to find it locally. I would expect that UPS or whoever to charge a Haz Materials fee to deliver an aerosol can of paint?? Do the chain auto parts stores carry this stuff? Any brands to avoid?
This is the first mod i did to my jeep. real easy, i went to my local advanced auto parts, and if they dont have it in stock theyll order it for you and have it in a day or two
i got the nite-shades at O'reilly's auto parts and then i used a duplicolor acrylic clear.
The link below is exactly the same paint i used. Just add the 3m scruff pad and your set.
http://www.amazon.com/VHT-NITE-SHADE.../dp/B0034L1GLE
http://www.amazon.com/3M-03193-Paint...7937620&sr=1-6
