Off camber concerns
Old Jun 12, 2011 | 07:53 PM
No1AP's Avatar
Default Off camber concerns
I was hoping to discuss a few topics and get a little bit of perspective from others.
I'll start off by telling you my setup and what I would 'like' to do next. I have a 2 Dr with an RE 4.5 LA kit intended for a 4 Dr which supposedly netted me an extra inch. Measured up next to my friend with a FT 4 in we sit about the same, however I have bumpers and a winch, so I figure I lost about an inch there which is all fine. I am currently on Pro Comp Xterrains 315/70R17, which should measure out to 34.4 but actually come in just shy of 34.
The terrain I wheel is what we have out in Tennessee, trails, dirt, plenty of off camber situations, steep climbs and descents that make me pretty nervous. I haven't come across something I couldn't make it up or over... yet. I stuff perfect and droop just a little too far. Springs unseat both front and rear, but that's a different story.
I want to move up to 37's. I love how they look, but I am not sure I should. I recently went out with a friend that has a stock Rubicon and was blown away by the places he went. Other than over a bit of rock that would have made clearance an issue, there wasn't anywhere I went he couldn't. A few places were easier for him because he wasn't worried about flopping where I was. Should I have been? I don't know.
All of this got me to thinking, if I go any bigger with my tires, it seems that I would be losing out in a couple of places. I believe under full stuff, even after trimming I would be limiting myself on up-travel. I don't know by how much, I've never been on an RTI ramp. I would have to run it twice, new and old, to have quantifiable, empirical evidence, which I am not willing to do. The other issue is how much more prone to a rollover I would be. Once again, I don't know by how much my critical angle would change. I know I could negate this by removing lift, but that would limit my up travel even more. Like I said, I am just trying to gain perspective on this, make sure I am thinking about this correctly.
Any insight anyone has, or possibly even reassurance that the change experienced would be negligible, would be great.
ID:	171262   Click image for larger version
ID:	171263   Click image for larger version
ID:	171264   Click image for larger version
ID:	171265   Click image for larger version
Old Jun 12, 2011 | 08:24 PM
w squared's Avatar
I can go a LOT more places on 3 inches of lift and 35's than I did with my stock Rubi.
If you want to go to 37's and don't want to extend your Bumpstops (much) then you could look at flat fenders. 4 inches of lift, flat fenders, and a little trimming should be fine.
If you're worried about stability in off-camber situations, perhaps the Currie Anti-rock would be worth looking into. A properly tuned anti-rock will help out if you're concerned about excessive body roll when you're off camber.
Old Jun 12, 2011 | 08:43 PM
No1AP's Avatar
It's more that I'm worried about rolling over while off camber. I've been sideways something to the tune of 30 degrees. I was way out of my comfort zone even though I apparently looked fine. I just don't want to get a taller tire and then find out that where I was before is too far now.
