Extended Breather Questions
Old Jun 14, 2011 | 04:59 AM
jhb26len's Avatar
Default Extended Breather Questions
So I'm looking to extend my front and rear axle breathers this weekend. Anything I should know? Do you just use the existing breather, use a double end hose connector and run the extended hose up into the engine compartment? Do I have it right or am I missing something? Oh and do you install anything on the end of the extended hose like a one way valve?
Old Jun 14, 2011 | 05:16 AM
Mark Doiron's Avatar
I am on my phone so it will probably be easier for you to find it, but follow the writeup in the Project-JK section.
Old Jun 14, 2011 | 05:29 AM
tslewisz's Avatar
This one:
http://project-jk.com/jeep-jk-write-...hose-extension
Old Jun 14, 2011 | 09:25 AM
Widowmaker's Avatar
Originally Posted by ukie jk
What about the transfercase and the transmission?
They are a bitch to get to but extended just like the axles. Trans(auto) is on fill tube and t-case is on top of housing....I forget where hose ends.
Old Jun 14, 2011 | 09:44 AM
Widowmaker's Avatar
If you get under the jeep and look up along the firewall you should see them. Mine had green 1 way valves on the ends.
Old Jun 14, 2011 | 10:27 AM
jhb26len's Avatar
I cant find the end of the breather hose on my 2011, it seems its already really high. help me out please?
Old Jun 14, 2011 | 10:40 AM
Cdyspeed's Avatar
The rear hose is on the pass side rear tire well and the front diff is attached on the upper shock tower ill take some pics give me a min
Old Jun 14, 2011 | 10:42 AM
Cdyspeed's Avatar
I hope this helps let me know if you have anymore problems
ID:	171711   Click image for larger version
Old Jun 14, 2011 | 10:52 AM
jhb26len's Avatar
wow thanks so much, i love this forum! anyways, are those just held in place by clamps and whats the best way to remove them so you can extend them to the engine compartment
Old Jun 14, 2011 | 11:07 AM
Pjohn's Avatar
May want to extend the tranny too.
