AEV Geometry correction front control arm brackets. I have Questions?
Old Jun 15, 2011 | 04:47 PM
08JKRHD's Avatar
Default AEV Geometry correction front control arm brackets. I have Questions?
Anybody running these?
Can anyone tell me if they would allow me to keep my stock driveshaft if I replace the boot?(I have a teraflex 2.5 coil lift and recently lost the boot from my drive shaft)
Will they still be helpful when I change to an aftermarket driveshaft? (I'm thinking Tom Woods)
Old Jun 15, 2011 | 04:52 PM
wayoflife's Avatar
JK-Forum Founder
the damage to your drive shaft boot is caused from the amount of droop you now have with your taller lift and installing control arm bracket will not do anything other than become a big rock target on your jeep. regarding drive shafts, just make sure to request spicer joints - otherwise you will just get cheap chinese made joints.
Old Jun 15, 2011 | 04:55 PM
mhaines's Avatar
Had them, took them off and put on adjustable arms. I went with a coast front shaft from Northridge.
WOL is right about them being targets for rocks
Old Jun 15, 2011 | 06:29 PM
08yellowx's Avatar
As far as I know, you cant reboot your front shaft. Parts not available.
