TF 2.5 Coil + OME Long Travel Shocks
Old Jun 16, 2011 | 04:56 PM
spyther's Avatar
Default TF 2.5 Coil + OME Long Travel Shocks
Hey guys, just finished ordering my lift components:
TF 2.5 coil lift
Spidertrax 1.5" Wheel Spacers
TF front lower adj. control arms
JKS Front + Rear Adj. Track Bars
OME LT shocks
I am trying to build this rig up for reliability as it is my DD (Over an hour highway commute every day), but also for performance. Dave at Northridge told me he recommended using the OME LT shocks in place of their standard size as he believed they would be too small. Is anyone else running these shocks in combination with the TF 2.5? If so what are your opinions? Any other suggestions for my rig?
Thanks guys,
and thanks Dave for the great deal you gave.
Old Jun 16, 2011 | 05:38 PM
srunyon's Avatar
TF 2.5 coil lift
OME LT shocks
Thanks guys,
I'm running the shocks but on the OME coils. The standard OME shocks are way short....their LT shocks really aren't as long as i was hoping. I'm also going with the Teraflex long arm kit for better handling/performance.
Old Jun 18, 2011 | 08:02 PM
spyther's Avatar
Thanks for the reply, looks like the long travels might be the way to go. Anyone else with experience?
Old Jun 19, 2011 | 09:08 AM
Zombie Hunter's Avatar
PDF file from arbusa: http://www.arbusa.com/uploads/PDF/ac...WranglerJK.pdf
"Extended length shocks are for 4-6" suspension lifts only and are not intended for use with any Old Man Emu systems. Extended bump stops are required."
Are OME Extended length shocks the same as OME LT (long travel) shocks?
Maybe Dave at Northridge could chime in to explain the difference?
Old Jun 20, 2011 | 08:26 AM
Northridge4x4's Avatar
Sponsoring Vendor
The LT shocks will not fit a 4-6" They are more like 3-4" lift shocks.
David
Old Jun 20, 2011 | 01:34 PM
spyther's Avatar
So just to clarify, they shouldn't be any problem with the TF 2.5 kit Dave?
Old Jun 20, 2011 | 01:38 PM
Sponsoring Vendor
No they wont be a problem but you will have to make sure your brake lines are long enough and keep an eye on your front driveshaft.
David
Old Jun 27, 2011 | 07:51 PM
spyther's Avatar
Yeah that driveshaft will be ripping sooner rather than later I'm betting lol.
Anyone else running this combo wanna chime in?
Old Jun 27, 2011 | 09:14 PM
CLuBMieST3R's Avatar
I'm lost here.. I just bought the OME nitro sports for my TF2.5 the (2-2.5 inch).. are those LT shocks? I'm confused, should I have gone bigger?
sorry for the noob question
Old Jun 28, 2011 | 06:41 AM
orfanidisnikolaos's Avatar
if your shocks are marked 'LT' then you have long travel shocks. Sport vs Standard has to do with stifness.
