original rims on big tires
Old Jun 19, 2011 | 08:27 PM
Default original rims on big tires
so i have not searched so please no grief. thanks so i have the sahara that came with stock 18s i want to put 35s on the original rim and prob powder coat it as well i seen it done but any problems would it be ok. wont be wheeling to much just here and there. thanks in advance. pictures would be awesome
Old Jun 19, 2011 | 08:57 PM
Jeremy072288's Avatar
I have 35s on a 16 inch rim. just a little rubbing but I got wheel spacers just to be safe. You don't want brand new 35s getting slice up lol
Old Jun 20, 2011 | 04:59 AM
Harbourone's Avatar
Wheel spacers will keep your new 35's from getting eaten up from the inside. I had 35's on the rubi rims with spacers and something else to look at is the distance to the pinch seam. I had 1" between the tire and the edge, that's something that can make contact even if you keep it on the road all day long.
Unless you're super addicted to the looks of the 18's or getting a killer deal on tires, I would suggest dropping down an inch or two in rim diameter to cut tire prices.
I'm running 37's with 4.5" lift and at stuff I'm still not contacting the stock pinch seam. Keep in mind the axle travels rearward when its flexes.
With anything wider then a 10.5" tire you will need wheel spacers to run the factory rims. It will get you a net backspacing of 4.75" which is pretty standard even when buying aftermarket wheels.
Old Jun 20, 2011 | 06:00 AM
walker111's Avatar
What size spacer? Is there just a standard 1.5"?
Old Jun 20, 2011 | 06:45 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
FWIW, the best spacer on the market is Spidertracs.
They are 1 1/2 " spacers.
Check the For Sale section. Sometimes they are in there.
Old Jun 20, 2011 | 06:55 AM
walker111's Avatar
Awesome, thanks. Had those on my TJ.
Old Jun 20, 2011 | 08:59 AM
jay01th's Avatar
Default Dont Do It
Dont Do IT
those rims weigh 22 lbs or so, get aftermarket that weigh only 16 lbs !
Old Jun 20, 2011 | 09:03 AM
scononie's Avatar
Originally Posted by jay01th
Dont Do IT
how would the OP benefit by 6lbs difference per rim + cost of new rims????
I'm running true 37's on my stock Rubi's No issues.
Old Jun 20, 2011 | 09:10 AM
walker111's Avatar
That statement would work better if we were on a racing forum...Jeeps however would not really feel (IMO) that difference in rotational mass.
Old Jun 20, 2011 | 09:18 AM
TURTLECON's Avatar
Like everyone said, you need spacers to get proper backspacing w/o rubbing. Also, either cut the pinch seam or take a mallet and whack that thing flat out of the way
