Help: What is this? Sway Bar Link?? Is it stock?
Old Jun 22, 2011 | 12:23 PM
bostonbuckeye17's Avatar
Default Help: What is this? Sway Bar Link?? Is it stock?
I need some help ID'ing this component...
1. What is it called?
2. Is it stock or aftermarket?
3. What should I replace it with?
The drivers side connector is broken. It won't stay connected.
It's either a stock piece, or possibly from a BDS lift kit.
I have a 3" BDS lift, and I can't remember if it was a part of that or not.
I'm trying to decide if I should take it to the dealership and get it replaced (lifetime bumper-to-bumper ($100 deductable), or if it's part of the BDS lift kid (it has a lifetime warranty), or if i should just upgrade it to something new/better.
as of now, I have 35" tires, 3" BDS lift, rugged ridge XHD front bumper, & superwinch on a 4 door unlimited rubicon. if that helps.
Thanks.
Name:	swaybar connect.jpg
Old Jun 22, 2011 | 12:36 PM
Northridge4x4's Avatar
Sponsoring Vendor
That appears to be a BDS sway bar disco.
Old Jun 22, 2011 | 12:43 PM
thanks for the quick replies, guys...
what is the risk of running around with that disconnected in the mean time?
Old Jun 22, 2011 | 12:46 PM
TURTLECON's Avatar
Ummm... you could lose control while turning and bad things will follow.
Old Jun 22, 2011 | 02:15 PM
nthinuf's Avatar
Being disconnected is great for offroad, but lets the body roll too much for onroad. If you need to run disconnected for a while, you can. Just take it easy and keep the speed down, especially in corners.
Old Jun 22, 2011 | 06:23 PM
Jeff76's Avatar
I run disconnected all the time in a 4 door with 40's. I don't run on the highway though and take corners a little slower.
Old Jun 22, 2011 | 08:30 PM
archijeff's Avatar
Why?!?! Disconnected eliminates the work the sway bar does.. Don't you notice the rig being very flighty?
