Winches and road salt?
Old Jun 23, 2011 | 03:53 AM
maine07jk's Avatar
Default Winches and road salt?
For those who have had winches mounted on the front of their jeeps in the winter, what has the salt and grime from winter roads done to it? Has it effected the outer winch casing, cable or otherwise made them into a rusty mess!
And no I don't want to move South or West out of the snow!
Old Jun 23, 2011 | 04:01 AM
jctnt1's Avatar
If it's not made with an aluminum case it becomes brown and if not rope the cable becomes brown. I just replaced one after 2 1/2 years and as I inspected the drum it too was brown and full of brown gunk, even the rope at the drum was polluted. I had a cover but the underside stayed exposed. I know both Warn and Superwinch have aluminum cased winches ie, Warn's 9.5ti.
Old Jun 23, 2011 | 05:33 AM
SiliconTi's Avatar
I heavily spray down my cable with WD-40 every Fall, and give the whole winch a light coating. The paint on the winch (Warn M9000i) is flaking off, but no rust.
Old Jun 23, 2011 | 08:00 AM
Yankee's Avatar
My Warn 9.5ti still looks good after almost 4 years of MI salt. Paint is still fine. I wipe the cable with an oily rag once a year. I am changing bumpers soon so plan to give it a good cleaning during the process.
Old Jun 23, 2011 | 05:22 PM
maine07jk's Avatar
Thanks guys. I want one bad, but want it to last and not get eaten apart by road salt!
Old Jun 24, 2011 | 04:14 AM
jctnt1's Avatar
You NEED a winch, go buy the Warn 9.5ti $80 rebate right now
Old Jun 24, 2011 | 06:31 AM
JMann2380's Avatar
Get the cti it's the same price and newer model. Best price I could find was Chris at Jeep Add-Ons
Old Jun 24, 2011 | 06:57 AM
BKGM Jeepers's Avatar
Most quality winch cases are made of either aluminum or another alloy. If you run rope instead of cable you'll also avoid rust there too. Then, you can run either a neophrene or vinyl cover to finish it off. The neophrene cover can be washed a couple times a year too to get the salt off. $55 for cover is cheap protection for both the rope and the winch itself.
I don't live in snow year round but I do a lot of snow runs and my T-Max is on year 10 and going strong!
Old Jun 24, 2011 | 05:54 PM
maine07jk's Avatar
Does the Smittybuilt xrc-10 comp series have an aluminum casing? I cant find it in the literature on-line.
