Do i need rear uca's on 3 or 3.5" w/ stock rear driveshaft?
Running an unlimited with 6 speed tranny and thinking of swapping my 2.5" teraflex coils for some slightly taller. I know I will need to address front castor, but do I need to do anything about the rear driveline with a stock shaft?
With a 4door, the rear shaft 'should' be ok at that height. Rear arms wouldn't hurt, but wouldn't be at the top of my list until you do replace the shaft with an aftermarket.
I have a 4 door with 3.5'' lift kit and 35'' and i dont have rear aftermarket drive shaft, only in the front. Going off road 3 times a month and nothing happens, but next year ill change my rear drive shaft just because im going 37'' and a little more hard core off roading.
