Hood Latch
This is a wierd one I bought the Daystars because I was stock and my hood was dancing like crazy on the highway,I recently installed a 2" lift and so far my hood has not moved
Is it not supposed to be worse when lifted?
Originally Posted by Jeepstown
I just fitted the "Drake hood latches" on mine and i absolutely love them... No more Hood flutter and they look sick
They are a bit pricy though
I had the same problem with the hood and decided to do some research on this. A few mention that if you just remove the spring, it should stop the fluttering. Another fix is using zip-ties. I do not recall exactly the trick to it, but it's not something you have to snip and re-tie every time you wish to open the hood.
I'll post it if I can find the link again...
