Anyone using Rock Krawler front coil clips?
Old Jul 16, 2011 | 05:11 PM
Battlefrog's Avatar
Default Anyone using Rock Krawler front coil clips?
I just got my Rock Krawler front coil clips and not exactly sure on the mounting procedure (no directions). I also have Teraflex rear coil clips with the same question. Any help, write-up or pics would be greatly appreciated.... Thanx
Old Jul 16, 2011 | 05:43 PM
renpia's Avatar
Here's a pic of mine on the passenger side. I just drilled into the spring perch base and just bolted the clip on. Works great!
Old Jul 16, 2011 | 05:45 PM
Battlefrog's Avatar
Did you have to drop the axle in order to do this ? It looks fairly simple in your pic. Thanx
Old Jul 16, 2011 | 05:49 PM
renpia's Avatar
Well, it looked simple. But I had to remove the coil to get the angle to drill the hole. If you have an angled drill, you will be set and it will be a simple install.
Old Jul 16, 2011 | 06:08 PM
Battlefrog's Avatar
I was figuring it sounded to good haha...
Old Jul 16, 2011 | 06:38 PM
Battlefrog's Avatar
Any more advice? After he does his he'll be installing a set on my 2dr as well.
Angled drill.......hmmmmmmm I think I had one of those.
GON WHLN's clips (now that I look thru my phone) passenger and driver side respectively
I guess I can put some new holes in the mango....
Old Jul 16, 2011 | 06:41 PM
saravonshep's Avatar
Ya their pretty simple to install. If you have an angle drill it would make life a whole bunch easier for the install.
Old Jul 16, 2011 | 07:01 PM
Battlefrog's Avatar
I've got 4 drills and not one is an angle drill....
