Prorock 44 unlimited??
I am kicking around the idea of replacing my D30 with one of these bad boys. My question is will it work with my set up? I have the AEV lift which uses the drop brackets for the front control arms and uses the factory control arms. I love the way it rides now so just hoping to maintain the ride quality.
Also, I have an atlas TC with 1310 yoke and will be using an aftermarket driveshaft.
My buddy is installing a pr44 right now with the aev kit. A lot of problems with the aev brackets. I think the pr44 tube diameter is 3" and stock d44/d30 is 2.5" so the brackets don't fit. Had to cut and weld them all on.
Just installed my AEV lift and unless the axles housing and tabs are exactly the same as the originals all of the brackets will have issues. To me it would be easier to find a used Dana off a similar model jeep that someone upgraded to 60s and is getting rid of. You could also call AEV, their customer service is pretty good and could point you in the right direction.
Instead I would build or have one built
Yes I am talking about the brackets attached to the axle. As the other poster stated, the drop brackets mount to the frame and have nothing to with the new axle. By cutting, I meant cutting the brackets to fit, not the axle. if you want to keep all the geometry exactly the same as stock, then get the standard model. The unlimited model has built in caster and pinion angle adjustments.
If you get the standard model and not the unlimited then you can use the stock arms. This is what my friend is doing. If you get the unlimited, you would need adjustable control arms.
