So a stock JK 2-door can fit 32s. My options aren't exactly that.
Old Jul 17, 2011 | 10:51 AM
gump9005's Avatar
Default So a stock JK 2-door can fit 32s. My options aren't exactly that.
So I'm looking at the Hankook DynaPros: http://www.discounttire.com/dtcs/tir...97006&pc=11959
Two options are:
LT285/70R17D1 121Q B which equals 32.70"
and
265/70R17 which equals 31.60"
When they say 32.70" do they mean with the tire over-inflated way past where I would normally inflate it just to get to that measurement? If I were to inflate it for road driving to a reasonable pressure might it measure closer to 32"?
I want a tire that won't require me to mod anything.
Old Jul 17, 2011 | 11:14 AM
photographix33's Avatar
My Jk 4 dr. came stock with BFG 32's, I don't see why 2 door should be any different.
Old Jul 17, 2011 | 11:47 AM
Phishjeep's Avatar
You'll probably be fine with the bigger ones. Its not that much of a difference.
Old Jul 17, 2011 | 03:20 PM
Shadow's_Jeep's Avatar
If you really don't want to mod anything, then go with the 265/70R17 and you will be fine.
Old Jul 17, 2011 | 04:09 PM
woodweavil's Avatar
Two options are:
and
You will be fine with the 285s
Old Jul 17, 2011 | 06:36 PM
coltc2000's Avatar
the 285 fit any jeep that came with 17'' or 18'' without a problem only slight rubbing on front sway bar at full lock. most who have upgraded go this size with no problems and no lift
Old Jul 17, 2011 | 07:02 PM
remingtonJK's Avatar
I am running 285/75R17 dynapro mt's on my 2dr. They are great for all conditions ( rock, mud, sand, ice). I'm running 28 psi on the street and 10 on rocks with the factory steel wheels. The only draw back is they are 10 ply so they are Heavy.
Old Jul 17, 2011 | 08:02 PM
gump9005's Avatar
And they don't rub at full flex disco'ed?
Old Jul 18, 2011 | 06:40 AM
guyp3's Avatar
Stock JK should fit 32's no prob.
Old Jul 18, 2011 | 06:47 AM
orfanidisnikolaos's Avatar
either size will work
