35 vs 37 gas mileage
Was wondering if anyone who had 35's and upgraded to 37's could give actual results. Obviously results will vary based on differences in equipment so maybe include your gear info as well. Also curious about changes in highway driveability. Thanks for the info.
4door auto, 3.73 gears, 315 75 16 (35") Toyo MT, I was getting between 14 - 16 mpg mixed driving, 70-75 on the hwy.
Changed to 37 13.5 17 Toyos, same conditions, now getting between 12-14 mpg.
Stock I was getting between 18-20 mpg.
Seems with every increase in tire Size there was roughly 2 mpg lost.
I just upgraded to 5.13 gears so I will see if that helps with mpg's.
You gotta get your shift points back in order. You should be around 2300 rpms at 70mph. I highly recommend ghetto procal! Nothing to install ance the dealer pcm flash upgrades don't affect it. Pay close attn to page 5 throttle tolerance absolutely run this procedure it will match the pcm and the pedal. Much better throttle response
Yes my Toyos are much heavier and slightly taller than the BFG's.
