Swap SwayBar Disconnect from outside to inside (Fulltraction Premium 3 inch Lift Kit)
I installed (Fulltraction Premium 3 inch Lift Kit) and it works good with my Mud Tire/Wheel.
The wheel is 16x8 with 4.25 backspacing
It is now rainy season in my area and I want to put my stock tire/wheel back, but this setup
has a 6.25 backspacing, making the rim/tire contact with the upper part of rear sway bar disconnect
It seems If I swap the disconnect from outside into inside, this problem can be solved.
Before I make this effort, I wonder if anybody did the same job and verify it is doable.
Thanks!
Thanks!
