What's with my JKS quick disconnects making a clunking noise....again.
I put on the JKS Quick Discos last month and all was fine till I got offroad. This is withoiut disconnecting them, the one on the right started clunking. I got on the bumper and rocked the front end and the right JKS would clunk, clunk, clunk every bounce. The drivers side was not makiong noise at all. When I got ome, I got under and untightened the shaft and tried to line up the bushing holders a little better, as the were not in the same plane. The noise went away, but now I'm getting a noise again by just driving locally. What am I doing wrong here. It seems that this should not be so difficult to align....and keep aligned. I must be missing something.
When you assemble them make sure you put red loctite on them.
The only time mine have made noise is when they loosened up. Why? Because I neglected to follow that step in the install instructions telling me to use a threadlocker.
Just got back from a trip to Colorado and Wyoming. I got noise like this about halfway through the trip (after Ouray). Switched them around and the noise has lessened. Gonna try the retightening ideas.
