Teraflex 2.5" Coil Kit Rear Swaybar Help
Putting in my new 2.5" coil lift from Teraflex and cannot get the top nut on the rear swaybar link to tighten up. The stud that is mounted on the top of the link just spins and there is no spot on the stud shaft to put a wrench like on the OEM rear link that I took off. Any help would be appreciated!
It is a nylock nut and when the nylon locking portion gets to the threads it just spins the stud.
Also, did everyone else get a grease zerk on their rear link from Teraflex like it shows in the video install? Mine does not have that.
Did you get a grease zerk fitting in yours? Mine does not even have a spot for one.
Thank RinkishJK! Didn't even see that allen head in the end of the stud! Teraflex just buzzes it on with an impact in the video! You would think they would fix their install instructions.
