2dr w/ auto trans lift...what should I get???
Old Jul 23, 2011 | 03:12 AM
blue project's Avatar
Default 2dr w/ auto trans lift...what should I get???
Ive been looking at the TF 2.5 coil lift. Ive heard that its possible for the drive shaft to hit the trans pan at full flex. Also heard of people chewing uo front shafts every 30k-40k. I don't need more than 2.5 but but current leveling kit just isnt enough. Anyone out there with a 2dr w/ auto run into these issues?
Old Jul 23, 2011 | 03:32 AM
orfanidisnikolaos's Avatar
The issues begin if you exceed 3inches of real lift. Then not only the front but the rear driveshaft need to be replaced, too in a 2dr auto. You won't have any issues with a 2.5 inches lift.
Old Jul 23, 2011 | 04:04 AM
Originally Posted by Freak
Are you speaking from first hand experience?
I killed a front driveshaft within 2k miles on my Teraflex 2.5. I also have 2dr Rubi auto. I recently killed my rear @ Rausch. Got at a 45 deg angle, gas'd it, and pop. Stripped the rear splines.
I wheel mine harder then most, but I would suggest swapping both the front and back.
What shafts do you recommend?
Old Jul 23, 2011 | 04:46 AM
My trail buddy has an x 2dr auto with a measured 2.5inch OME lift and doesnt have any problems. Mine is an x manual with the same setup and i dont have any problems, either. I have more than 10000km with this setup. I quess it depends on how hard you wheel your jk.
Old Jul 23, 2011 | 08:29 AM
Christine's Avatar
I've got a 2.5" BB lift on 33's. I don't have any problems. I wouldn't go any higher though, this seems to be a good height to get over everything I'll encounter.
