4 hi, lockers and e-disconnect working?
Old Jul 23, 2011 | 07:36 AM
marybicon's Avatar
Default 4 hi, lockers and e-disconnect working?
i read that long time ago here but cannot find this tread anymore, i remember that if you cut the right wire under the center armrest, you ca put your lockers on and unlock your swaybar same if you are on 2wd or 4 hi, anybody remember that?
Old Jul 23, 2011 | 08:03 AM
orfanidisnikolaos's Avatar
Just buy a super chip and you will be able to use your rubi lockers in 4hi. Don't know about sway bar disconnect though...
Old Jul 23, 2011 | 08:42 AM
marybicon's Avatar
no, my friend have one and the only thing it do is locking your rear diff on 2 or 4 hi, for 500$ i prefer to cut a wire and do everything i want when i want. thanks to you by the way
Old Jul 24, 2011 | 05:53 AM
marybicon's Avatar
no one really remember that? the only thing you do is to cut a wire to give you a what you want to do when you want. probably it's only the transfert case position switch wire that you have to cut. except for that nothing give a signal to the computer to not lock the diff because you are on hi?
Old Jul 24, 2011 | 05:57 AM
single's Avatar
Is this what you are looking for? Google is your friend.....
hxxp://www.rockcrawler.com/techreports/jeep_rubicon_locker_bypass/index.asp
or this:
hxxp://www.wanderingtrail.com/Mods/TJLJmods/Locker_Defeat.htm
or this:
hxxp://www.stu-offroad.com/electrical/rubi1/rubi1-1.htm
Old Jul 24, 2011 | 07:08 AM
marybicon's Avatar
found it!!!!! youtube, just to write jeep jk locker override bypass, you will see the 6min video of how to. really help me!!!! good luck to the other guys who want to try it
Old Jul 24, 2011 | 10:57 AM
aermotor's Avatar
Do you really need lockers in 4 Hi? Sounds like a recipe for gear munching. It's your Jeep and YMMV.
Old Jul 25, 2011 | 01:46 AM
Old Jul 25, 2011 | 07:03 AM
marybicon's Avatar
no, for sure i dont want to ride ful ock in 4 hi, maybe i will just do the rear set-up, i live in Québec and we ride in deep snow and ice long time belong the year and it will be really nice to ride rear lock. the only thing i like to do is ride in 2wd with sway bar unlock, belong time i ride gravel road it smooth the ride alot!!!!
Old Jul 25, 2011 | 07:44 AM
BKGM Jeepers's Avatar
Snow and a rear locker are fine in 4-hi. I don't think I'd run the front.
Im really interested in by-passing my e-swaybar 18mph cut off. I can't stand it reconnecting each time I drive 20 mph...
