TF 2.5" Coil lift and TF leveling kit, best of both worlds
Old Jul 27, 2011 | 02:22 AM
Markdsv's Avatar
Default TF 2.5" Coil lift and TF leveling kit, best of both worlds
Not sure if this has been done before but I have installed a TF 2.5" coil lift as well as TF leveling kit and I am very happy. I also installed coil wedges what seem to work well correcting my coil position. My jeep is noticeable higher and has still the stock ride without going for the coils for a 4" lift. Has anybody done this before?
I noticed a lot of bottoming out when I was on expedition, my jeep was very much loaded in the back, I hope with the extra inch lift I won't bottom out so much, time will tell of course. I am slightly concerned as I haven't change my EKLA's so they are still officially only for a 2.5" lift, so far so good.
I was also amazed how abrasive mud is as I had almost no paint on my skid plates, axles and chassis anymore so I couldn't resist to take of my axle and paint it properly......
Old Jul 27, 2011 | 04:51 AM
Tuto's Avatar
The paint Job looks great. I only wish jeep have done it from the begining at the factory -
Old Jul 27, 2011 | 08:00 PM
Markdsv's Avatar
Indeed, why does jeep give it so little attention, I was shocked with the amount of rust on my jeep being only 10months old
Old Jul 27, 2011 | 08:37 PM
jesse0376's Avatar
I had the leveling kit and just put the 2.5 inch coil lift but only kept 1 spacer in the front was thinking I could put the other fronts in and rears down the road if I feel I need it. I would rather go with flat flares and trimming than more lift IMO.
Old Jul 28, 2011 | 02:37 AM
Mark Doiron's Avatar
I have about 1.5" or rear end sag with the hardtop (and MBRP rack) on and partly loaded down. I have a new set of OME HD springs to replace the rear TF 2.5" coils and see what that provides. After that I may need to add a spacer to the rear. But, I also run this Jeep without all of the heavy hardware, so need a solution that doesn't require adding spacers just because I have the softop installed. I hope the OME springs suffer less with changing weight than the TF.
Old Jul 28, 2011 | 02:59 AM
Markdsv's Avatar
Hi Mark,
Let me know how you get on. She drives fine at the moment, actually better than I had expected, I think the adjustable trackbar helped spacing out my axel as well. I am also impressed with the coil wedges, keeing the coils nicely in line and I would definitely recommend these.
I haven't run her with the top off.....mmmmm.....you might be right that with the hardtop and MBRP off I might be struggling with the 'reach' of my ELKA shocks, didn't think about this......let's see how it goes.
I haven't installed the spacers in the front as jet, maybe I can find time this weekend.
Old Jul 28, 2011 | 03:57 AM
Olean NY Jeeper's Avatar
Interested to see how it sits when u finish, make sure you post up some photos when done. this was the route I was thinking of taking but went with clayton 3.5 coils. I just ordered yesterday so I dont know if I made right decision.
Old Jul 28, 2011 | 06:00 AM
Originally Posted by Markdsv
... I am also impressed with the coil wedges, keeing the coils nicely in line and I would definitely recommend these...
Already have. Yes, they do their job well.
