Teraflex Steering Damper Help
Help I just noticed the way the Teraflex steering damper is put on.
The installer put mine on the other way around.Will it make a difference.
I have no problem at the moment except for my ESP coming on when exiting off a ramp or at higher speeds on curves.(Mind you I know that I have to re center my steering wheel it is off by about 1/2 inches).
I've seen then put on both ways, don't think it really matters as long as it's not gonna rub on anything. Maybe it does though..... if so you can swap in pretty easily.
Originally Posted by orfanidisnikolaos
It doesnt matter which way as long as it doesnt come in touch with anything. As for the esp problem is because your steering wheel is off.
