AEV Snorkel - any tips before i install?
Old Jul 28, 2011 | 07:20 PM
JKPier's Avatar
Default AEV Snorkel - any tips before i install?
Got one on the way. Any tips appreciated before i starting cutting metal...
Also, is tbis comoagible with cold air systems?
Old Jul 28, 2011 | 07:27 PM
Zombie Hunter's Avatar
Measure twice before cutting.
Works with factory airbox only.
It is a true cold air intake.
Old Jul 28, 2011 | 07:36 PM
Fenrir's Avatar
Make sure the printer you use to print off your template is calibrated correctly. Compare it to all your parts, cuz when mine printed, it printed too small...
Also, TAKE YOUR TIME. If you rush it, you'll F it up. Your actions should be thought out and deliberate if you want it to look good.
After I cut mine, I taped it up later and painted the exposed area for a more finished look and to protect it from rusting.
Old Jul 28, 2011 | 07:38 PM
wxjeep's Avatar
Measure twice before cutting and make sure you have enough cutting disks prior to starting. I cut mine using a 2" hole saw and a dremel with the cutting disks. I went through one of the fiber reinforced cutting disks and 4 of the standard stone cutting disks.
Old Jul 29, 2011 | 01:45 AM
Mark Doiron's Avatar
You'll be cutting through two layers of hood sheetmetal. The first layer is easy--I used a cut-off disk (after making the initial 2" holes). The inner layer is tougher to access. I tried the cut-off disk and it was a pain. I tried a reciprocating saw and it would not fit. Then I tried my air nibbler. What an easy job! If you don't own one, beg or borrow one and it will be a lot easier. Be certain to place a tarp over the exposed engine bay to catch metal shavings/cuttings--there will be plenty.
Also, the instructions have you fill the holes in the bottom of the stock air box with sealer. You need to do this or it will be exposed to water entry, of course. However, DON'T do it when the instructions say to! Install the air box first because those holes let you peer through to the engine bay and align it quickly and easily. Otherwise, you'll be trying for quite a lot longer than necessary to get it lined up and pushed into place. Once you get it properly seated, put that sealer over those openings.
If you'd like to retain a CAI, but have the snorkel there when needed, RIPP offers a new product. There are good reasons to do this: The snorkel robs about 30HP according to dyno tests (of a supercharged JK).
http://www.rippmods.com/JEEP_Wrangler_KIT_2007_2011_RIPP_Cold_Air_Kit_for_ p/0711jkcai-snrk.htm
Good luck!
Old Jul 29, 2011 | 01:55 AM
wrangler07's Avatar
Save the beer until AFTER the install.
Old Jul 29, 2011 | 01:28 PM
burbingus's Avatar
From what I've read, most people can expect a slight performance boost while after installing a snorkel due to the CAI effect. I think the reason it reduces the power on the supercharged JK is due to the lower volume of air as compared to the intake the charger comes with.
Also, as I understand it, the AEV snorkel is incompatible with other CAI kits, but you don't really need those anymore after installing your snorkel because it does a better job of delivering cold air to the engine.
Old Jul 29, 2011 | 03:15 PM
LidLess07X's Avatar
If you are going to use a hole saw, use a variable speed drill with a clutch -type chuck that will slip if it binds up which will prevent the pilot bit from breaking and sending a 600rpm hole saw down the side of your Jeep
Old Jul 29, 2011 | 03:20 PM
JKPier's Avatar
Yikes. Sounds like experience talking? Could always call a racing stripe I guess.
Old Jul 29, 2011 | 03:24 PM
danmojo82's Avatar
Where were you when I needed that advice?
But with the hole saw, take your time, go nice and slow. Like he said, if you go to fast you will break your pilot bit which will REALLY piss you off, trust me. Go slow with it, once it starts a little bit of a groove you can pick up the pace a bit and cut through.
My scar.
My brand new pilot bit that was used for about 10 seconds
