Rock Krawler 5.5 vs 3.5 mid arms
Old Jul 31, 2011 | 12:54 AM
AndrewCote's Avatar
Default Rock Krawler 5.5 vs 3.5 mid arms
I have a 2 door, and im trying to decide if the 5.5 is to tall for it, seeing as how i wont be able to buy 37's for a while, and i have cut flares. i could get the 3.5, and i do have some 1' spacers i could use to do 4.5.
Will i need drive shafts for the 3.5?
are there any rk 5.5 owners out there?
Old Jul 31, 2011 | 03:52 AM
Olean NY Jeeper's Avatar
the 5.5 Rockrawler is way too much lift for 35s. U can run 3.5 with 37s if u trim pinch seam and fenders or run flat fenders. u can always add once inch coil spacers like you said when you go to 37s or add a body lift if u want more clearance.
Old Jul 31, 2011 | 11:39 PM
AndrewCote's Avatar
anyone running a 5.5?
Old Aug 1, 2011 | 06:53 AM
Rock Krawler Suspension's Avatar
Former Vendor
Our dominant sales are 2.5 and 3.5 lift heights. Not alot of 5.5's. 5.5's are big. You won't need a 5.5 to run 37's on your 2 door.
RK
Old Aug 1, 2011 | 06:57 AM
TXJimmy's Avatar
I think 5.5" is too much lift for 35's
Here is the 3.5" RK lift
Old Aug 1, 2011 | 07:19 AM
dinojeep's Avatar
I know there is someone here running the 5.5 with 37s. But don't do it with 35s. Just get the 3.5. I'm going to be ordering the 3.5 and I plan on someday running 37s with the mods listed above.
Old Aug 1, 2011 | 09:49 PM
AndrewCote's Avatar
Thanks yall, ill go with the 3.5, will i need driveshafts with this kit? i dont have the extra coin right now for that
Old Aug 2, 2011 | 01:04 AM
From what I have heard from people with this lift, u get 4 inches up front and 3 in the rear so with a 2 door u need a rear shaft eventually. My driveshaft started to die after lifting my jeep but it took a while. I wold make it the next thing on ur list to upgrade.
