Sway bar disconnects
Old Aug 1, 2011 | 01:40 PM
GIJK's Avatar
Default Sway bar disconnects
What cheap alternatives are there for disconnects? I tried using cotter pins from tractor supply but they pop off when I corner on the street.
Old Aug 1, 2011 | 01:59 PM
JayhawkJeep's Avatar
Veteran: Navy
JKS a cheap (at least for a Jeep mod)
Old Aug 1, 2011 | 02:05 PM
pettym's Avatar
The JKS's aren't all that expensive and I have never had one pop off or open up on me on the road. If you're ever in the sterling/herndon area and want to check out a set, let me know.
Old Aug 1, 2011 | 02:08 PM
nthinuf's Avatar
There are a few write-ups in the write-ups area...
https://www.jk-forum.com/forums/show...327#post533327
Teraflex and JKS are both over $100, but RC's disco's are $60.
Old May 10, 2012 | 03:46 PM
GIJK's Avatar
Ripped off my rigged up disconnects this weekend. Finally installed a set of trailmaster JKD disconnect for $60. They look great and are sturdy and functional. Ride is sturdy again!
Old May 10, 2012 | 04:16 PM
Cozmik's Avatar
I'm a big fan of my Teraflex disco's. Easy to use, pin up out of the way when disconnected and hold your sway bar in place.
Old May 10, 2012 | 04:28 PM
drivingfool's Avatar
I've had the teraflex discos going on 5 seasons (northeast), ~10,000 miles and they're legit. You have to be on flat ground to reconnect easily.
Old May 10, 2012 | 04:32 PM
MotiCross's Avatar
Don't go for the cheap way when it comes down to sways... if you drive high speed and one fails.... yea.... no good.
Go with either JKS (what i have and it is much heavier duty then all the others) or teraflex... ( only good thing about TF is that you attach it after where the JKS you just take off and put a side... no biggy to me.. very simple)
