Rough Country Body Lift with 6 Speed
Old Aug 1, 2011 | 10:42 PM
bobbyspaghetti's Avatar
Default Rough Country Body Lift with 6 Speed
Okay so I am thinking of putting in the 1.25" rough country body lift and am wondering if anyone with a 6 speed is using the shifter adapter with any sucess? I also wonder how the bumper relocator will work with my aev tire carrier on the stock bumper. So is anyone using this kit with the adapter? Specially in cold weather seems to be an issue as well, causing it to come out of gear in the even numbered gears 2, 4 and 6.
I just need a little more lift for tire room and dont want to spend any more money on a suspension lift. Plus dont want to run into driveline angle issues.
It seems there is a fair number of people that end up removing their body lifts as well and although body lifts are pretty cheap I dont want to be pi$$ing away money.
Old Aug 2, 2011 | 03:59 PM
Default orly
Someone must be running this on a 6 speed. Bump.
Old Aug 2, 2011 | 06:48 PM
qf4phlyer's Avatar
I have the 6 speed with the RC body lift and adapter kit. No problems at all, very satisfied.
Old Aug 2, 2011 | 07:53 PM
BadPunkin's Avatar
If you search my threads I did a write up on this. I had a very bad experience. I currently have cut my upper boot rather significantly to stay in gear.
Old Apr 30, 2012 | 02:04 PM
Default Update
Just an update I ended up doing the Rough Country 1.25" body lift. I got the shift adapter and the rear bumper relocation brackets. I did find that it still wanted to jump out of gear though after so I ended up getting a leather shift boot as it was the upper boot not the inner causing problems. Also because I have the AEV rear tire carrier and it mounts to the frame and the body I had to get creative to make up the difference after the body lift.
Old Jun 26, 2012 | 03:12 AM
sky's Avatar
sky
Thanks for the update. I just got this lift from another forum member.....wish me luck!!
Old Mar 18, 2013 | 07:56 PM
Deucefour's Avatar
How did you get the shifter lever OFF of the tranny stub shaft once you removed the screw? Mine wont budge at all!! Trying to install that shifter adapter and the lever wont come off the tranny for me to even put it on. Any help much appreciated!! Thanks!
Old Apr 20, 2013 | 07:16 AM
TokenMSJ's Avatar
Bit late but just wiggle and pull on the lever... Took me about 10 minutes of cussin' before it popped off..
Old Apr 21, 2013 | 10:21 AM
Hmmmm mine came off fine which is weird because nothing goes easy on my Jeep. As everything is rusty or covered in mud. Did you end up getting it?
