My first set of questions....
Old Aug 2, 2011 | 11:05 AM
XAFSSGT's Avatar
Question My first set of questions....
I am trying to get all of my questions out at once. I have an 07 Wrangler X.
I want to lift it, and I was wondering about this kit:
http://www.roughcountry.com/jeep_jk_3-seriesII.html
Does this kit include everything that I need? If not, what am I missing?
How many hours is install typically?
Also, I am looking at 33in BFG MT KM2 with 4.88 gears:
hxxp://www.4wheelparts.com/Tires/BF-Goodrich-Mud-Terrain-KM2-tires.aspx?t_c=13&t_s=156&t_pt=100697&t_pl=6396
Will those fit on my stock 17's from Jeep?
What kind of fuel economy should I expect?
I appreciate any help.
Last edited by wayoflifette; Aug 2, 2011 at 11:24 AM. Reason: please don't post links to non sponsors
Old Aug 2, 2011 | 11:23 AM
SilverJK12's Avatar
In short answer. Yes . But it has fixed control arms. Some ppl like adjustable control arms to help with changing castor angle if wanted. Another thing I don't see if Trac bar and quick disconects. These are not needed... Maybe in time you might want these and replace as needed. I started with a rc lift and eventually replaced with teraflex 4 inch and adjustable control arms , Trac bar, and quick disconnects by jks. So based on what you are looking for and doing with your jeep this lift is perfectly fine. If you are wanting to go bigger tires down the road or more flex the quick discos may be something you can add later. Cheap too.
On the gearing . Do you have standard or auto?
They should be fine with the stock wheels.
4.88 gears for a manual seem too much of a gear for 33s. I have 4.88 on my manual with 35s maybe 37s in time. This is why I ask auto or manual. You will be probably fine with 33s and stock gears with manual if you have this.
Ppl are getting various fuel economy. Don't expect to get good economy the bigger you go or bigger lift you go. Weight and height play a part with drag resistance and rolling resistance.
Old Aug 2, 2011 | 11:32 AM
XAFSSGT's Avatar
I have an automatic. Unfortunately.
Thanks for the information.
Old Aug 2, 2011 | 11:33 AM
SilverJK12's Avatar
With an auto you need more gear. I suggest you get the lift you want and 33s . Try it out and if you don't like them then re gear. I doubt you do though. A lot of guys run 35s and stock gears. Do you know if you have 3.21 or 3.73 gears?
To keep cost low. The RC lift is great and if needed you can replace for disconnects and all in time like I did. It really depends what you are using the jeep for daily driver or weekend offroader.
Old Aug 2, 2011 | 11:35 AM
XAFSSGT's Avatar
Actually, I ran the VIN number on a website and it gave me a full breakdown and it said I have 4.10 gears.
Old Aug 2, 2011 | 11:38 AM
SilverJK12's Avatar
Cool. Didnt know x came with 4.10. You are perfectly fine then with gears and 33s. No need to change to 4.88 at all. Get your lift and 33s and you will be good to go
Old Aug 2, 2011 | 11:41 AM
D_engel's Avatar
do you have a tow package?
Old Aug 2, 2011 | 11:43 AM
SilverJK12's Avatar
He has to have it with 4.10. Although mine initially did too with 3.73 though. Maybe he has an upgraded gearing.
Old Aug 2, 2011 | 12:05 PM
XAFSSGT's Avatar
This is my daily driver as well. Won't it be a slug with 4.10 gears?
XAFSSGT's Avatar
Man, I wish I knew. I don't have a trailer hitch on the back.
