Has anyone installed a Gas Door?
Old Aug 2, 2011 | 05:01 PM
CherryJeep's Avatar
Default Has anyone installed a Gas Door?
Has anyone installed a Gas Door? I know silly question but I bought a door and I want to install it but it didn't come with any directions.
Old Aug 2, 2011 | 05:04 PM
smanenti's Avatar
Typically the door will simply mount over the existing hole and would be secured via 4 self tapping screws that go into the plastic (factory) inner sleeve.
Takes :30 seconds to install. Did mine in no time flat.
Reach back out if still unclear. Good luck - they look great when on!
Old Aug 2, 2011 | 05:13 PM
PainKiller's Avatar
if you bought this brand http://www.youtube.com/watch?v=MwHvn6xnIhE
Old Aug 2, 2011 | 05:21 PM
greenenvey's Avatar
yeah the brand would help a couple of them install diffrently
Old Aug 2, 2011 | 08:22 PM
raidue's Avatar
I did rugged ridge and yeah took less than 2 minutes. Very pleased with it thus far.
Old Aug 3, 2011 | 03:20 AM
OldTex's Avatar
Howdy,
I installed the Mopar door last week end. It replaces the inner part which holds the gas filler neck also. It took about 30 minutes. You have to remove the tail light to reach in and release the tabs which hold it to the body. The hardest part was the rubber gasked which holds the filler neck in the center of the inner part. It wasnt that hard and looks good too. Have a goodun!!!!!
Old Aug 3, 2011 | 04:23 AM
Hskr4x4's Avatar
Same here...
Here is a link for install. If you dont have lock this install takes just a few minutes
http://www.quadratec.com/Assets/Installation/93889.pdf
Old Aug 3, 2011 | 06:37 AM
CherryJeep's Avatar
Originally Posted by Hskr4x4
Same here...
Thats the one I got! Man this forum is GREAT!
