Left Rear Brake Line Bent By Lift
Old Aug 2, 2011 | 05:11 PM
JKZinger's Avatar
Default Left Rear Brake Line Bent By Lift
Wheeled with my New Teraflex 2.5" coil lift w/shocks last weekend and was just checking things out. Noticed that my left rear swaybar link bolt yanked down and bent up my metal brake line. Has anyone else had that happen and what did you do to fix it?
Old Aug 2, 2011 | 05:15 PM
Zombie Hunter's Avatar
Here's a thread on that.
https://www.jk-forum.com/forums/showthread.php?185551
Old Aug 2, 2011 | 05:39 PM
Originally Posted by ECHO
Extended my brake lines prior to adding my lift
The OP said swaybar end link bolt yanked his metal line.
Old Aug 2, 2011 | 06:26 PM
Guess I should have read it closer.. OOop's
I figured as much. Usually your responses are accurate, informative and dead on.
this is for you ECHO!
