rear driveshaft at the Tcase seal question
Old Aug 3, 2011 | 05:25 PM
MOKOS's Avatar
Default rear driveshaft at the Tcase seal question
So, on the transfer case there's a rubber seal that's perpendicular to the machined end of the yoke on my tatton shaft I'm putting in. Doesn't seem like there's anything on the tatton yoke to meet up with the rubber seal on the transfer case. On the stock flange, there's a thin metal piece that met with the seal on the old flange. That thing didn't seem like it wanted to come off without getting bent. Do I need to install this thing on my new yoke or will the silicone in the splines and behind the nut be enough to keep the fluid from leaking?
anyone else who installed a tatton shaft or similar yoke have experience with this?
Old Aug 3, 2011 | 05:41 PM
mkjeep's Avatar
Just install the new yoke, dust cover not needed off the stocker.
Old Aug 3, 2011 | 05:43 PM
MOKOS's Avatar
I read this was the case at the diff ends. It's the same with the tcase end?
Old Aug 3, 2011 | 05:49 PM
mkjeep's Avatar
I don't have one on mine.
Old Aug 3, 2011 | 06:22 PM
MOKOS's Avatar
alrighty, I'll assume you have no leaks then. just didn't seem right to me but I guess I'll give it a shot.
Old Aug 3, 2011 | 07:38 PM
mkjeep's Avatar
My yoke just squishes into that rubber seal. Thousands of miles, no leaks.
