Jacks stands while you install a lift
I'm going to be installing a teraflex 2.5 coil/shock, with front lca's, and new front and rear trac bars, this weekend.
I put on my 2.5 RC lift using just two jack stands at a time, switching from back to front. Have any of you done the same? Is it worth buying two more so I can lift the entire vehicle at once?
Also, has anyone installed a lift in the rain? Haha
Either way works, but it's always handy to have a couple extra stands and their not expensive. No rain installations for me. Just do the job with safety in mind, can't enjoy the new mods if you're squished
I used 4 when I installed my lift. At a later date when I installed my RC front LCA's I used 4 also, 2 on the frame and 2 to hold the diff, I don't trust jacks.
Sears makes a nice Truck/SUV high jack stand.
IMO, you can't have enough safety equip, 6 heavy duty stands and 4 light weights for holding the Fiat.
I have always installed lifts one half at a time (front and back). Doing it this way is also a little safer because you are keeping one half of the vehicle firmly on the ground. Unless you have a professional lift like they have at shops, I would recommend this method.
Never tried it in the rain though. I have a large garage and work in there.
I've got a few sets of 3-6 ton stands from Harbor Freight that I use all the time to hold the whole vehicle up. I'll be doing that tomorrow while installing my new lift. Makes tire rotations easier too.
