I wanna run 33 ...what lift should I do
Old Aug 4, 2011 | 11:20 AM
big c's Avatar
Default I wanna run 33 ...what lift should I do
I wanna run 33 what lift should I do ... also when u add bumpers and what not wont the weight lower the jk so should I get a higher lift to keep good clearance
Old Aug 4, 2011 | 11:31 AM
IcyFridge's Avatar
You can run 33s on a stock JK.
However, if you want to run a wider 33 like a 33x12.50R17 tire, then you will either need new wheels with 4.5" of backspacing or wheel spacers if you use your stock wheels.
I run a Budget Boost with my 33s and it works great. If you plan on adding a bunch of heavy bumpers to the Jeep, then look into a TeraFlex 2.5" coil lift, which works really well for people on here.
Old Aug 4, 2011 | 12:33 PM
big c's Avatar
I was thinking about the 2.5 coil lift by teraflex... I'm thinking about a leveling kit now
Old Aug 4, 2011 | 12:41 PM
big c's Avatar
What if I did both ha
Old Aug 4, 2011 | 12:46 PM
Notakar's Avatar
x2 on leveling kit.
Ordered my Cooper STT 285/75/16 this morning
Work in Progress - JK's Avatar
x2 on this, there are a few write ups about this exact lift and tire size that I read before I went with a bigger lift and 35's.
Old Aug 4, 2011 | 01:00 PM
woodyvw9's Avatar
Veteran: Coast Guard
I run the Teraflex BB with 33's and it works great. It is not quite level though so eventually I will throw in a 3/4" spacer or upgrade to the Teraflex coils.
Old Aug 4, 2011 | 01:16 PM
IcyFridge's Avatar
If you run the 2.5 coils with a levelling kit, you might need to address the driveshafts since that would put you over 3" of lift.
I would stick with only the levelling kit and 33s.
Old Aug 4, 2011 | 01:19 PM
RyanMcCall's Avatar
i just got 33s for my stocker, I am working a building an overland style jeep, nothing to crawl rocks. Gotta say 33x12.5 with the proper backspacing on a two door stock suspension looks damn good. check my profile
Old Aug 4, 2011 | 01:46 PM
IcyFridge's Avatar
I know that cbeas runs a 305/65R17 (33x12.50R17) BFG AT on a levelling kit along with wheel spacers. I think it is the perfect example of a balanced JK.
