Hissing noise after intake install
Just installed a k&n intake. If I accelerate lightly on the gas I hear a hissing noise comming from the hood. If I press hard on the gas It goes away And I get that deep noise I was looking for. Is this a serious issue? Anyone had this?
Big problem is I drive standard so my foot is hardly on the gas and I can really hear the hiss especially from 1-3 gear.
Suggestions?
Suggestions?
your going to have a slight sucking noise, shouldnt be to evident other then the throaty growl a normal intake will give you...did you hook up your breather hose? that could be it. other then that I would inspect all of your straps to make sure they are tight.
Originally Posted by Swelly77
Your going to have a hissing noise when acc. with a CAI. You also will hear a deeper rumble once on the gas harder.
