Dynomax "rock crawler" exhaust help!
Old Aug 4, 2011 | 03:43 PM
jesse0376's Avatar
Default Dynomax "rock crawler" exhaust help!
I just installed this exhaust and it looks like the rear trackbar would hit the exhaust when flexed. Anyone else have this problem? also im running the TF 2.5" lift with the trackbar bracket.
Old Aug 4, 2011 | 04:39 PM
jeepken's Avatar
I've been meaning to start thread on same issue. I just installed mine and noticed the exhaust pipe is touching the trac bar. Interested to hear others input as I gave not yet called Dynomax customer support. They were awesome on my last call though.
Old Aug 4, 2011 | 04:47 PM
jesse0376's Avatar
mine is really close to the tow hook in the rear?? looks like it might hit if i drive on the river bar or a bumpy road.
Old Aug 4, 2011 | 05:33 PM
terminator 03's Avatar
Default .
I just installed mine on sunday and had the same problem what i did was cut about six inches off of the pipe and installed the muffler, pushed it back as far as it would go then tightened all clamps this gave me about 4 inches of room to play with
Old Aug 4, 2011 | 06:11 PM
psujeep2198's Avatar
Interested in this. I was going to install this on my Jeep this weekend. Its been sitting in my garage for a month. I also just installed a RK 3.5 lift with a rear trackbar bracket. Any other ideas?
So far, I'm not doing too good on the "get more power out of the engine" mods. Got a superchips and then found out it does not work on 2011's and now this...
Old Aug 4, 2011 | 07:06 PM
jesse0376's Avatar
with mine it needs to move back towards the rear of the jeep an inch or so to clear good but then it might be to close to the axle.
Old Aug 5, 2011 | 06:36 AM
Marshall's Avatar
Ive been waiting on mine for over a month....soooooooo, I guess ill see when it comes in.
Old Aug 5, 2011 | 06:56 AM
Dynomax's Avatar
Sponsoring Manufacturer
Check over this thread there is some good hints in here.
https://www.jk-forum.com/forums/show...hlight=dynomax
Unfortunately we can't anticipate all the combos of suspensions out there, but Terminator 3 suggestion is a common fix.
And as Jeepken mentioned our tech line is really good as well. 734-384-7806
Old Aug 6, 2011 | 06:41 PM
Sorry, I couldn't find any hints. Has anyone done this with a rear track bar bracket and it worked?
I tried to attempt this today but couldn't get stock exhaust off. With the trouble getting the stock exhaust off, I want to make sure this will work before cutting stuff off. Thanks for the help.
