rear driveshaft removal?
Old Aug 4, 2011 | 07:39 PM
vgullotta's Avatar
Default rear driveshaft removal?
Does anyone have any tricks to getting a stock driveshaft to pop out of the rear differential? I'm having a bitch of a time with this thing.
Thanks in advance,
Vinny
Old Aug 4, 2011 | 08:24 PM
Denny2565's Avatar
Look at post #52
https://www.jk-forum.com/forums/show...ter-Lift/page6
Old Aug 5, 2011 | 03:27 AM
jake_kinney's Avatar
If you don't have a punch to do that method, hit the outside of the yolk with a soft face hammer while spinning it with your other hand. The vibration will break the rust loose and it should pop out. If that dosent do it grab a normal hard faced hammer and give her a few whacks. Same concept as an impact driver basically.
Whenever I have to pull a trans or do something were drive shafts have to come out and it is a CV style, the hammer never fails.
Old Aug 5, 2011 | 12:07 PM
vgullotta's Avatar
Thanks for the suggestions. I am hitting it with a hammer, both on the shaft itself and on a bolt I stuck in that unthreaded hole down there, but it's impossible to get any leverage on it. Soooooooo frustrating!!!!!
