My JK will barely push itself down the road!
Old Aug 5, 2011 | 12:46 PM
BlackNblueJK's Avatar
Default My JK will barely push itself down the road!
I have an '07 JK that will not maintain 70 mph up a small hill or against a slight head wind without down shifting (auto trans). I could see a mountain or a 30mph wind but it does it all the time. Does anyone else have this problem? Any ideas why or how to fix it? I have 33's and a 3' lift. It did it before with the stock tires also.
Old Aug 5, 2011 | 12:49 PM
NH-JK's Avatar
You need to get a super chips programer.
Old Aug 5, 2011 | 12:50 PM
Croce's Avatar
Driving from Phoenix to Flaggstaff i was pushing 4k+ rpms most of the time on every hill i climbed.. I have a superchip and it did help a little
Old Aug 5, 2011 | 12:58 PM
Ryan0260's Avatar
Turn off your overdrive. Also what gear ratio are you running? If you don't know call a dealer and give them your vin#
Old Aug 5, 2011 | 01:04 PM
medic_23387's Avatar
Sounds like u need to re-gear.
Old Aug 5, 2011 | 01:10 PM
Ryan0260's Avatar
X2. 488 gears and a superchips programmer
Old Aug 5, 2011 | 01:16 PM
Originally Posted by chip80
Something isn't right. Even upgrading to 33s shouldn't cause the kind of power loss you are describing. I'm assuming you've checked all of the maintenance related items - air filter, plugs, etc. that could affect performance. How many miles do you have on it? What kind of fuel have you been using. You may want to run a couple of bottles of injector cleaner through the engine and see if premium fuel makes any difference. Although I doubt it would be this - a restricted cat convertor causes major power loss.
You are talking small inclines and not crossing the Rockies, right?
yeah, small hills even just the freeway drive home. I run 87 octane and i also use a lucas fuel treatment sometimes. It did it with the stock 31" tires too. I'll have to check the gears. It only has 43,000 miles. I do regular maint. I am getting ready to do the tranny fluid and front diff, I might even look into changing the transfer case fluid even tho the book says its good for the life of the vehicle. Thx. Keep the ideas coming.
mudrunner's Avatar
You don't really need to chip it. I have a 3.5" lift with 35s and I just put 4.88 in two days ago, and have no problem now top speed is 75 at 35 hundred rpm but has so much power 6th gear accelerates up a hill and can increase speed just fine.
Old Aug 5, 2011 | 01:23 PM
Supro's Avatar
I'd say 4.10 or 4.56 for 33's.
Old Aug 5, 2011 | 01:25 PM
kb1's Avatar
kb1
If your running a 3.21 ratio this would definitely be the problem. Heck, I have a 3.21 ratio on 31's with a 6 spd and it's a dog. Definitely need a re-gear if this is the case.
