pro comp 2.5" lift. front track bar adjustment
Old Aug 6, 2011 | 12:05 PM
1sicjk's Avatar
Default pro comp 2.5" lift. front track bar adjustment
I just installed the Pro Comp 2.5" w/ mx6 shocks on my jk. Installation was a easy but there is no way to adjust the front track bar. the kit had come with a cam bolt for the rear but nothing for the front. I ordered a adjustable track bar today but the instructions didn’t say one was required and reading all the reviews no one ever mentioned having to adjust it. I measured my wheels and my drivers side is out 3/4" further than my passenger side. did anyone else have this problem?
Old Aug 6, 2011 | 01:53 PM
Zboilla's Avatar
Yes this is typical for all kits, your pro-comp kit should have given more in the neighborhood of 3-3 1/2" this in turn pulls the front axle over only to be corrected with an adjustable track bar. Which track bar did you order, I have an pro- comp one here that I would gladly give you.
Old Aug 15, 2011 | 01:44 PM
Jk47's Avatar
How do you like your pro comp lift?
Old Aug 15, 2011 | 01:51 PM
arasco85's Avatar
i have 2.5 coil lift with skyjacker. mine also moved. obviously due to the track bars. i will eventually get adjustables
