Spacers?
Old Aug 6, 2011 | 06:13 PM
gregfly's Avatar
Default Spacers?
I know when you install spacers you need to use Loc tite and torque everything. But if you reinstall wheels because of rotation or tire replacement do you need to retorque spacers. And if so, will I have to remove them all the way and reapply Loctite?
Old Aug 6, 2011 | 06:40 PM
Ryan0260's Avatar
Re torque them every time you rotate and balance them 80-90 lbs
Old Aug 6, 2011 | 06:42 PM
erpeden's Avatar
You shouldn't need to remove the spacers for tires or rotation. If you do remove the spacers for maintenance or repair you should torque and use lock tite just like the initial install
Old Aug 6, 2011 | 07:26 PM
JKSLEEPR's Avatar
Originally Posted by ECHO
Eaxactly what those two gentleman said.. always re-torque
x2 always re-torque
Old Aug 7, 2011 | 10:44 AM
gregfly's Avatar
Ok, thanks for the good info.
