2.5 - 6" compatible sway bar disconnects on a stock lift.
Old Aug 19, 2011 | 01:22 PM
Midgear's Avatar
Default 2.5 - 6" compatible sway bar disconnects on a stock lift.
sounds retarded I know.. but I bought these disconnects thinking I could install them without a lift. Guess I shoulda researched a bit more before buying.
The question is: What would happen if these were installed on a Jeep with no lift.. ? I know it wouldn't be a good thing, so I don't plan on installing them without one. Just curious as to what kind of destruction would take place, or if theres a way to perhaps make it work.
These are rough country quick disconnects compatible with 2.5" to 6" of lift. I have no lift at all.
Old Aug 19, 2011 | 07:18 PM
Midgear's Avatar
bump (insert more letters to make a valid post ect ect ect ect wajdbawekrjgaebnkaejrbn)
Old Aug 20, 2011 | 02:24 PM
Tuto's Avatar
If they are long you can cut them.
Old Aug 22, 2011 | 02:27 PM
Midgear's Avatar
I actually thought about using the hardware supplied to perhaps install on the Jeep but use the stock links since they are the correct length.. not sure how that'd work- need to look at the hardware. Just an idea. I'll do some comparison. Might need to just lift it lol
Old Aug 22, 2011 | 02:55 PM
nthinuf's Avatar
Originally Posted by Brian Rubi8
collapse them all the way down and compare them to the stock ones.
X2
Having short links is bad, (there is quite a bit of pictorial evidence of this) and most will suggest that you get the swaybars at least level after a lift, but a bit positive is better. Unless you have a serious amount of up-travel, I don't see that you will have an issue running them at the shortest setting.
