275/70/18 Duratracs w/o spacers or leveling kit
Old Aug 20, 2011 | 07:57 AM
Remington19's Avatar
Question 275/70/18 Duratracs w/o spacers or leveling kit
Can I run this setup without problems ? If not, what is the easy/inexpensive correction?
Old Aug 20, 2011 | 08:29 AM
20JK10's Avatar
You may rub the front bumper and frame rail at full lock when turning. You really won't need a leveling kit unless you disconnect your front swaybar.
For the price of those tires in 18", you might save some money [at least down the road] by getting a set of aftermarket 16" wheels with a 285/75/16 tire or 17" wheels with 285/70/17 tire. More are available in 16/17 and are cheaper.
Old Aug 20, 2011 | 12:20 PM
would spacers take care of the rub at full lock?
Old Aug 21, 2011 | 06:15 AM
bump for more information
Old Aug 21, 2011 | 06:35 AM
Firehound's Avatar
Wheel spacers will do the trick if you're using stock rims, or have at least 4.5 backspacing on aftermarket rims. You wont rub on the street but once you start flexing you may rub your fenders
Old Aug 22, 2011 | 05:24 AM
The above post doesn't look good, imo
Old Aug 28, 2011 | 11:40 AM
anyone have pics of their setup like this
Old Aug 28, 2011 | 02:15 PM
eric1213's Avatar
I have this exact setup, but I have installed a body lift and as for rubbing while turning, I just added 2 washers per side on the steer stops and trim the air dam a little.
Old Aug 28, 2011 | 03:27 PM
20JK10's Avatar
I don't think spacers will help. When I had my 285/70/17 Duratracs, I had them on ProComp 17x9 wheels with 4.5" back spacing, and they rubbed at full lock.
Old Aug 28, 2011 | 03:48 PM
Thanks, look at all the post under the show your 33 posts but it takes forever,lol
