17x8.5 Wheels with 4.63" BS (Hutchinson/AEV) rubbing issues?
Old Aug 21, 2011 | 02:03 PM
Mallow's Avatar
Default 17x8.5 Wheels with 4.63" BS (Hutchinson/AEV) rubbing issues?
I was interested in a 17x8.5 wheel that hs 4.63" BS and wondering what kind of issues I will run into with not going 4.0" - 4.5" backspacing. Currently wanting to run 35's but don't wan't to rebuy wheels if I end up running 37x12.5. So is anyone running into issues with 37's on 4.63" backspacing want to comment?
Thanks
-Mallow
Old Aug 21, 2011 | 03:30 PM
Mallow's Avatar
Thanks Planman. If I wanted to stick with 35x12.5 then would the same steering considerations come into play?
Old Aug 21, 2011 | 03:39 PM
Gatewood's Avatar
Default 5" bs
im running 37 13.50s on 5 in bs no prob not even close. steering stops set like they came from factory. works for me. the tires im running are 37-13.50- 18 swamper m16s and they are a full 37- 13.50. the wheels are xd rockstars 18-9 5" bs.
Old Aug 22, 2011 | 07:49 AM
Mallow's Avatar
Anyone mind taking some picks to show how far out to the fender flares they are (straight down, directly behind)? I have Bushwacker flat flares and trying to make sure the tread width stays under them due to state inpections.
Old Aug 22, 2011 | 08:02 AM
Mallow's Avatar
It appears those should pass inspection (Just a little bit of the tread showing past fenders). Thanks for the pictures and verifying for me that they should work.
