RK Tierod Ends??
Old Aug 22, 2011 | 04:18 AM
MikeyB's Avatar
Default RK Tierod Ends??
I picked up a RK Tierod someone had laying around. I ordered Moog 3624 ends but they are to too big for the RK. I asked the guy I got it from and he thinks he ordered it in 09.
Did RK change the design any? Not sure what ends to get now.
Old Aug 22, 2011 | 05:34 AM
MikeyB's Avatar
Some searching looks like 1st gen TR requires TREs that are not available anymore. Going to call RK to see. Anyone have the 1st gen TR?
Old Aug 22, 2011 | 05:46 AM
Bustabizz's Avatar
Former Member
Yeah ES3624 is the correct ones, not sure what changed on them? I thought they always have used the stock Pitman arm TRE.
Old Aug 22, 2011 | 06:10 AM
WhiskyPirate's Avatar
Weird that they would have changed ends
I installed the my RK tie rod with the same moog ends a couple months ago with no issue. The guys at RK are really awesome, I'm sure they'll be able to help ya figure it out.
Old Aug 22, 2011 | 07:52 AM
MikeyB's Avatar
1st gen:
Heavy Steel about 40-50 lbs
Uses smaller Moog ES 194R ends
2nd Gen:
Lighter
Uses Moog 3624 ends
Old Sep 1, 2011 | 07:02 PM
rubi08unlimited's Avatar
I think I have the first gen Tie rod based on the weight. I've had it for about a year. However the rubber on the Tie rod ends has cracked all the way through and is now disintegrating. how long should these tie rod ends hold up?
Old Sep 2, 2011 | 04:28 AM
MikeyB's Avatar
If they are greasable, they should last awhile. If not lifetime will vary but if its always covered in mud then not very long.
Old Sep 2, 2011 | 06:11 AM
Rock Krawler Suspension's Avatar
Former Vendor
Moog ES194 R's would be the part number you need for the first gen tie rod...
RK
Old Sep 9, 2011 | 06:11 PM
any thoughts on why the rubber would have split so fast? they have no fittings. Does anyone else run this setup and have you checked the rubber?
