installed esp/esc override switch, is bld still active?
Old Aug 22, 2011 | 07:03 AM
DanieltheManual's Avatar
Default installed esp/esc override switch, is bld still active?
I know if you do the hokeypokey it is still active, what about now with the kill switch.....
Old Aug 22, 2011 | 07:05 AM
Shortbuss's Avatar
Nope it's off with the switch. Makes a big diff on hill climbs ect.
Old Aug 22, 2011 | 07:59 AM
Which makes the diff? On, off? Bld?
Old Aug 22, 2011 | 10:25 AM
Shortbuss's Avatar
Huge diff with it on. It will still let you spin like mad if need be. And it just jeeps fighting for traction wherever it can find it! It's amazing in my opinion.
Old Aug 22, 2011 | 10:38 AM
I wana use bld, with esp off, without the dance......any thoughts?
Old Aug 22, 2011 | 10:47 AM
Shortbuss's Avatar
Yup 4 low. ESP and abs are both shut off in 4 low. But the bld is still active. Whenever I'm offroad I always use 4 low. The ESP kill switch in my opinion is just for screwing around and doing donuts.
Old Aug 22, 2011 | 10:54 AM
I know that much, I want bld to keep working in 4hi, with esp off....even in two wheel would be nice.....esp off in two wheel let's my 3.21 corner in 3rd w/o throttle cutting out...imo, esp is too sensitive, I'm a better driver than the program thinks......but think bld is the cats arse...
Old Aug 22, 2011 | 05:10 PM
Shortbuss's Avatar
I hear your pain. My two door has 3.21s. My 4 door has 4.11. Way better. For what you want you need to do the steering wheel dance or get the dealer to shut it off.
Old Aug 22, 2011 | 06:02 PM
Ya, just a temp fix for 2wheeling.... Need a piggy back w signal interrupters....just need the voltage cues..want to have bld on all the time, can do without throttle cut or any g-sensor/steering wheel feedback...ahhh...almost too easy
