Grinding when coming to a hard stop from front brakes?
Old Aug 22, 2011 | 02:41 PM
cameron7's Avatar
Exclamation Grinding when coming to a hard stop from front brakes?
hello
i noticed a little while ago that when i apple the brakes hard it feels like the brakes grind and i can feel it through the peddle...
some information:i have a 2010 jku with a 3.5in rough country lift with teraflex front and rear trac bars and 35 nitto mud grapplers...
if anyone has any information that would be great thanks!
Old Aug 22, 2011 | 02:50 PM
Battlefrog's Avatar
Is it coming from front or rear or both. My suggestion, take off your tires and check the brake pads as well as your rotors. The bigger the tire (heavier) the harder it is on your brakes. If this is the case, I'd look into a different setup; heavy duty...
Old Aug 22, 2011 | 02:51 PM
walker111's Avatar
Uh.....brakes? Check your pads.
Old Aug 22, 2011 | 02:52 PM
cameron7's Avatar
its just coming from the front and i went in for my service at the dealer and they said my brakes are fine...
Old Aug 22, 2011 | 06:27 PM
jeeeep's Avatar
it still does it after the dealer checked them? dumb question but have you looked at them and do the rotors look smooth, pads look ok -not glazed?
do you have pics of rotors? look for rocks that might be stuck in the pad area, if the drums are gouged, they will feel like that under hard braking.
Old Aug 22, 2011 | 08:03 PM
cameron7's Avatar
thanks for the responses
im going to check my brakes tomorrow in the light
and i would if i still had the stock tires...
Old Aug 22, 2011 | 09:26 PM
notenuftoys's Avatar
Been in the mud lately?
Old Aug 26, 2011 | 02:24 PM
cameron7's Avatar
No I haven't
I checked that first
Old Aug 26, 2011 | 02:44 PM
taylorthedude's Avatar
Check your hub assemblys also. Jack up the wheel thats making noise and rock it back and forth. There shouldnt be any play in the wheel, it shouldnt be able to wiggle back and forth otherwise your bearings are shot and will making similar noise that you described
Old Jan 2, 2014 | 07:41 PM
valeeum's Avatar
did you figure out what was wrong with your rig? i'm having the same exact issue. i'm gonna try what was suggested above tomorrow but curious to see how things ended up on your end. i have a rubicon unlimited with aev 3.5" premium lift, 35" KM2's, and relatively new rotors/brakes.
