Sreamin Demon Live Wires & Coil Plug Gap???
Just bought the Screamin Demon Live Wires and Coil and I've read
some guys saying they are opening the Spark Plug Gap to 65? If you
are using this system please respond. Thanks!
Using it now - runs great. with the greater energy from the Screamin Coil you need to open the gap. Wider gap increases spark and better fuel burn.
I bought a second set of plugs and gapped them all to 65, kept stock plugs in case I wanted to go back to stock. It fired right up traveled 4000 + miles so far on and absolutey no issue, runs much better than stock.
With the SuperChips tune I noticed a real difference between 87 tune and 91. At higher elevation I got great mileage. now back in TX with 87 tune can feel the difference. Going back to 91 tune until I get regeared next week.
BTW - I installed and left next day from TX to Utah, Moab, Salt Lake all over trails, mountain roads and back 4000+ miles in 10 days runs strong. once I regear I should see better mileage with 87 tune
Performance Distributors Screamin' Demon Coil and LiveWires using Autolite Platinum Spark Plugs.
Got it direct from Performance Distibutors, go to their website (not sure if I can post their URL) - alot of good info there
Much more responsive at the petal and idles smoother also!!!
Morris4x4.com $189.00 + 10% off + $21.00 next day FedX
Last edited by wayoflife; Aug 27, 2011 at 06:48 AM. Reason: do not post direct links to non-sponsors
